| Diesel Tech Diesel-powered discussions, all makes and models of 4x4's. |
Hi All, Just wanted to share a scare I had recently with my 2006 Dodge Ram Cummins with 5.9l 24V HO. I've been getting all kinds of Error Codes. Sometimes the truck didn't want to start. Then the lights on the dash and radio would start to flash off/on. I could only start it when the "PARK" was visible on instrument cluster. When I could get it running, it would start flashing headlights on/off as well as the dash and radio. These are the Error Codes I was able to get using my Superchips Power Programmer that also doubles as a scanner for troubleshooting: P2509 - ECM/PCM Power Input Signal Intermittent P0463 - Fuel Level Sensor Circuit High Voltage U1403 - Implausible Fuel Level Signal Received U1421 - Implausible Ignition key off time received C2206 - Vehicle Configuration Mismatch U0021 - Low Speed CAN Communication Bus (+) Open U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module It was getting very discouraging. One thing is for sure, it never left me stranded and I like my Cummins that much more now. After chasing the problem for a few days, I finally got close--it was definitely electrical. I came across some supporting information on different Dodge forums that stated the battery might be bad and causing the ECM (Computer) to act weird. These new trucks will electronics need a good source of 12V and ground to keep them ticking. I check the batteries (2) and found the negative post on the passenger side didn't look very sturdy. It was an older battery, about 4 years. I checked voltage and they were both over 12.6, still within spec. The other Optima Battery is only 6mo old. Since I still had my doubts about the old battery with the bad negative terminal, I swapped it out with another one. After tightening and checking all the post, and making sure the ground wires on the fenders and block were secure, the Ram started right up without any more problems. I've been driving it around town for about 1 week now and I haven't had any issue. I was able to clear all the Error codes using my Superchips Performance Programmer after making the fix. I'm off on a 800 mile trip this week, so I'm hoping it stays this way. Wish me luck. I'll touch base again with my trip to report and how the Ram behaved. Hope this helps others having similar issues.
__________________ DezertScorpion Last edited by DezertScorpion; 02-09-2011 at 12:38 AM. Reason: typo |
| Sponsored Links | ||
Advertisement | ||
Wow! Yeah it's amazing how dependant these trucks have become on the batteries and electrical system. It's both a blessing and a curse. I've got an early '04 Ram 2500 4x4 with the 5.9L and love it as well. I'll keep this all in mind, however, I did recently change out my batteries with some Interstates and haven't had any problems, yet. Hope your trip went well!! |
| Sponsored Links | |
Advertisement | |
« Previous Thread
Next Thread »
| Thread Tools | |
| Display Modes | |
