dirtbikes, to racing, snowmobiles or just general off road stuff. Sponsored Links | | Diesel Tech Diesel-powered discussions, all makes and models of 4x4's. |
04-29-2008, 12:26 AM
| | Aprentice | | Join Date: Sep 2002 Location: AZ, near Tucson
| | Stretching the diesel dollar
My Jeeps both run on gasoline, but when I don't need them for the power or traction, I drive an old Volvo diesel. For the last 18+ months I've been running it on ~10% used crankcase oil, saved from years of oil changes. It also has some ATF and gear oil, and maybe some paint thinner, too.
It runs the same on this mixture as on straight diesel. It stinks a little, but not much. I carry a spare fuel filter, because even though I pump the oil through a fuel filter before putting it in the tank I have gotten a plugged filter.
This may not be for everyone, but this oil that was worthless is now $4.00/gallon saved. I would rather have biodiesel, but this is cheaper and handier.
I swear, I'm not nuts - I was a diesel/heavy equipment mechanic for 35+ years!
__________________
Don't force it - - get a bigger hammer!!
04-30-2008, 05:45 PM
|  | Moderator | | Join Date: Jul 2004 Location: Oregon
No way. This is too funny!
I'd rather smell like french fries going down the road, but this is awesome. Diesel is $4/gallon here too.
04-30-2008, 07:39 PM
I use an electric fuel pump and filter from a junked gasser Volvo to pre-filter the used oil. Before that, I store it in a 55 gal drum mounted on its side, with a small hole at the bottom for dewatering. I seal the hole with a sheet metal screw with a gasket. I draw oil from the drum from the small bung, through a regular bung valve. This is about 1-1/2" above the dewatering hole.
As to the question of air pollution: I used to handle used oil processing for an oil recycling service to pick up, at a Copper mine. They just hauled it to a lime plant where it was burned for fuel. At $4/gal, I'd rather do it myself...
__________________
05-12-2008, 08:59 PM
|  | Carpal \'Tunnel | | Join Date: Mar 2001 Location: Massachusetts
Great idea!
06-02-2008, 12:44 PM
Diesel just hit $5 here now.
| ATV Reviews - Honda, Suzuki, Yamaha, Polaris, Kawasaki, Can-Am. First rides to long-term tests, check out the latest in ATVs, UTVs and Side-by-Side vehicles of every make and model. Read expert opinions and follow custom project vehicles. | Axxxtion Sports..... Axxxtion Sports is heating things up with their 2010 Winter Heat snowmobile calendar! Simply Sexy! | All times are GMT -5. The time now is 06:26 PM. |
