Every Jeep owner knows how important it is to be fully equipped and ready to meet any obstacles you may encounter when go off-road and a flat tire is one of them. While some tire carriers block the access to the rear door of your Jeep and you need to take them off every time, Fab Fours Off-The-Door Tire Carrier features dual rotating axis, that allows the tire carrier to open with the Jeep door, while performing the function of the regular tire carrier.
Fab Fours tire carrier is one of the most innovative carriers you can find for your Jeep. Featuring 2 stage matte black powder coat finish, it comes with 5-point mounting system, pre-drilled holes for high-lift jack mount and third-brake light attachments, integrated automatic locking pin, integrated CB antenna mount and turn buckle to eliminate vibration. Built from 3/16" Steel it has a heavy duty construction for extra durability and strength. This carrier retains OEM receiver hitch and wiring locations, which means it can be easily mounted into the rear of your Jeep with no modifications.
We've prepared the video for those, who wants to see the whole installation process:
Fab Fours® - Black Off-The-Door Tire Carrier
Keep your Jeep on the road with Fab Fours Black Off-The-Door Tire Carrier at CARiD!
