Re: Raptor Kill Switch
Replying to my own Post after Technical research.
The kill switch (one that makes continuity when pulled) attaches to the positive (+) pulse wire coming from the pickup coil from the Stator to the CDI unit. This kills the signal to the CDI unit for firing the Coil. If you have a Tech Manual reference page 8-9 (box #9) and graphic
page 8-11. The cluster of wires/terminals is under the left side cover next to the frame just under the rear of the tank.
Locate the 4 wire terminal [Red, White/Green, White/Red, White/Blue] and Splice to the [White/Red] coming out of the terminal, which is the (+) pickup coil wire. I Spliced by using a splice terminal and routed the grounding wire to the Coil Mounting bolt.
We have Kill. |
