OFF-ROAD FORUMS
Forums & discussion groups that offer a place for off road enthusiasts to chat, share answers, post photos, swap tips and discuss news and events from the off road nation.
ADVERTISEMENT
Go Back   Off-Road Forums & Discussion Groups > Ford Forums > Ford 67-96 F-Series, 78-96 Bronco
Old 01-16-2007, 07:23 PM
Journeyman
reddoogone is an unknown quantity at this point
Default fuel pump keeps running 88 F250
I have a 88 f-250 custom pickup 302 5spd 2wheel drive. Its ben sitting for 2 years. Only ran on the farm for wood a couple times.I replaced brake lines, changed fluid. The fuel pump keeps running . I understand it builds pressure and is supposed to shut off. But it doesn't shut off. Its hard starting sometimes. A shot of starting fuid and it starts. Any Ideas guys?
Old 01-26-2007, 08:02 AM
Aprentice
MudLake is an unknown quantity at this point
Default Re: fuel pump keeps running 88 F250
I had the same problem on my 89 f150 last week.
I opened the hood and gave the fuel pump relay bank a rap and it stopped running. Changed the relay for 23.00 dolars and it it OK now.
Hope this helps
Old 02-24-2007, 05:39 PM
Steve83's Avatar
Steve83 is an unknown quantity at this point
Default
reddogone
That's typically a sign of a dead EEC, but that's the LAST thing to replace because it's the most expensive & least likely (in general). Get a Haynes manual & a cheap multimeter, and see if the relay is sticking because the EEC is holding it on, or if it's mechanical (like MudLake's was). In either case, read the thread linked below.
MudLake
For a LOT less money, you could have cut off those crappy Ford-style relays & swapped in the more common, more RELIABLE Bosch/ISO style relays used on '92-96 trucks. Read this thread.
Search this Thread:
Advanced Search
Need Gas Mileage & Power?-
Off-Road Videos -
ATV Reviews -
