Read Before Posting. -Please try the search button. It can work miracles, as if you have a problem, its likely that somebody else has had the same problem aslo.
-Keep the bad language to a minimun.
-When asking a question, please include anything about the vehicle we may need to know to make our reply that much more accurate. year, motor, trans, axles..........
-Respect the other members.
-Label topics correctly, as "help" would get less info than "wheel bearing removal trouble" would. also, label off topics "O/T".
-Turn the caps lock key off, AS THIS IS SHOUTING. painful to read isn't it?
-Fill out you BIO, it does help.
-Use proper punctuation.
-If you post asking for help about a probelm, report back to us on what it was, and what fixed it so we can help others.
-Make shure your post is in the proper forum for your question.
-Posts must be appropriate. Remember, people of all ages read this.
-I will edit/delete posts that I see unfit. If I modify/delete your posts I will PM you telling you why I did this.
[img]images/graemlins/cool.gif[/img] [img]images/graemlins/smile.gif[/img] [img]images/graemlins/laugh.gif[/img]
Feel free to PM me with any questions, complaints, or problems you might be having.
Yes, every bronco owner with big tires knows that you can make yoyr tires rub on the radius arms at full lock! Its not a big deal....
Also, please Search.
Espicially if its about your auto or manual hubs, your rusting out tailgate, your tailgate window not working, removing the top, and what tires fit stock, and what tires fit with what lift.
thanks
Zach |
